Door Window Alignment
I have had a search, but unsure how to get the driver's door window to align correct with rear pillar window.
I have tried resetting the window regulator by holding button down 15 seconds, then up for 15 seconds, but this did not work.
Is it a matter of door card off and seeing and perhaps realign. Hoping there is a easier solution
Hopefully found a fix, with help from another Z4 owner, the video shows how to realign the window.
https://www.youtube.com/watch?v=TJ3FkjeL9TE
My car was the rear window that moved. Just couldn't see any adjustment, had to open some holes and add washers to move the rear glass. Last resort i couldn't work out where adjustment was.
Why or how it moved to start with, don't know.
Need to compare the two rears, are they symmetrical. You could draw around onto sheet of paper to compare, what i did.
Then work out which as moved, the door glass or rear glass.
Cheers mate, have measured and it's front door glass.
Here's a official guide
https://charm.li/BMW/2009/Z4%20sDrive30i%20%28E89%29%20L6-3.0L%20%28N52K%29/Repair%20and%20Diagnosis/Windows%20and%20Glass/Windows/Window%20Glass/Front%20Door%20Window%20Glass/Adjustments/51%2032%20154%20Adjusting%20Left%20or%20Right%20Front%20Door%20Window%20Glass/
