Door to Body Electrical Connector
McSwerve
Site Supporter
Trying to track down an airbag warning light and it’s been suggested I remove and clean the main electrical connector between the door and body ( battery disconnected).
There’s a small bolt to remove (done) but any tips to remove?
Is it just a matter of pulling or is there a harness retainer.
I can’t see anything and have searched to death.
Any guidance gratefully received.
If I remember correctly once you have undone the 8mm bolt, it pivots up from that point and is a clip at the other end?
To follow this up / for future reference…..
You undo the retaining bolt
Slide the whole connector vertically, so it comes away from a tab retainer in the door frame.
Then on top of the connector block there’s a retaining clamp that you need to gently pull vertically, that then allows you to pull the connector apart.
Pics for reference.
Hasn’t solved my airbag issue as yet (I seem to have made it worse as the code reader can’t now ‘see’ the satellite unit) but it may help someone.
