There's plenty of options for sound deadening material on the web , i went for a foil backed bitchman type that is self adhesive , easy to cut and use and does the trick just fine, dont be fooled by the hype or branded names. A sheet 500 x 1000 mm will be plenty to do both doors.
I bought mine of ebay from ghost-audio-accessories for about £20
'Sound Barrier' by Ghost Audio Accessories is a fantastic Sound Deadening made from a black bitumen type material. This fantastic 'Sound Barrier' Sound Deadening can be used for many things such as In Car Audio Systems, Road Noise and Vibrations, Heat lose and much more. With a trading history of over 25 years we can assure you that this 'Sound Barrier' will not only give you good value for money but will also give you good Sound Deadening for your In Car Audio System and reduce Road Noise and Vibration.
2M X 1M sheet of good quality 'Sound Barrier' car sound deadening
Easily applied to flat surfaces such as car doors, roof and boot
'Sound Barrier' Sound deadening is ideal for killing annoying rattles or vibrations caused by in car audio systems (ICE)
One of the easiest and most effective ways to improve sound quality
Excellent for reducing general road noise
Adhesive backing for easy application - simply clean surface and stick on! Applied easier if the 'Sound Barrier' Sound Deadening is slightly heated
Easily cut to shape
Black bitumen type material
Reflective surface on 1 side increases heat resistance
'Sound Barrier' Sound Deadening comes in 10 different lengths; 1m, 2m, 3m, 4m, 5m, 6m, 7m, 8m, 9m and 10m.
The last bit was taken from there site hope this helps
