Door/leccy mirror problem
Robster68
Decided to finally tackle passenger electric mirror intermittent not unfolding problem and tinny door close sound,hopefully just a good clean and relube and sound deadening should sort it, .Anyone else had this same problem? bit the bullet and bought new drivers side sound insulation and chrome line door pull trim from Hubaur-shop for good prices.
As expected blow out with compressor clean and lube worked a treat,now for the other side.
Aha, been suffering with one mirror not folding down for a year and a half now.. Didnt know that the plastic "door" underneath can come off. I shall ive this a shot too. which parts exactly did you lube up? would be great if that could be pointed out on the picture if thats alreight by you
gave it a good blast with WD40? or just siar blasted it and then used standard door hinge oil? do let me know as im definitely curious
Used wd40 silicon spray,blew all the crap out with my compressor,haven’t had a problem since,did the other side also.
I’ve only just got it back on the road after fitting new battery so can’t tell you for sure the door feels and sounds more solid when you shut it and I think the facelift e85/86 has this as standard,the door card inside is a mod I saw on bavsound YouTube channel which I did because I have a lot of sound deadening left over and it certainly won’t do any harm.
