Door caps
marcop123
Hi
Does anyone know where I can get replacement caps one is left door handle other are in center below transmission ?
Or what the Center cap is called to search it I think found the door handle but can’t find the other and good to order together
E86
Try Kis . :thumbsup:
https://z4-forum.com/forum/viewtopic.php?f=13&t=125150
Thanks for the plug! Still got loads of these if anyone is interested! Damn sight cheaper than the dealer as well!
Only have the console covers… not the door handle one!
If you have a 3D printer or access to one, here is a link from Thingiverse so you can print your own.
https://www.thingiverse.com/thing:2418998
The designer suggests using PC (polycarbonate) vs PLA due to the expected heat build-up in the cabin of the car. PC is also stronger and should hold up quite well over time.
Below is a description of PC's attributes and uses from the Raise3D website.
"PC (Polycarbonate) is a strong thermoplastic 3D printing filament that characterized by its excellent impact resistance, high stiffness, heat resistance, and flame retardant properties. As a result, PC filament can absorb impact, prevent deformation or cracks, and maintain stability under high temperatures and flames. Due to its 110°C heat resistance, PC performs well in high-temperature environments, such as under the hood of a car. Also known for its impact strength, PC is commonly used for producing rigid parts, function testing, finished parts assembly, and manufacturing."
Said designer is our very own IamOrion... the guy who printed the ones I’m selling. As I said in my thread we’re collaborating together to bring these to members. I referenced the file in my thread for those fortunate to have a printer :)
