Spent most of yesterday doing the intake clean. The actual removal of bits to get to the intake manifold wasn't as hard as I thought it would be EXCEPT the 'junction box' that is attached to the underside of the manifold cover. An absolutely mare to remove, despite the 2 seconds it took the guy on the video. I simply could not depress the metal tabs enough to slip them under the plastic brackets on the junction box. I read through the comments and found a comment from another viewer who said they also found it impossible, and instead unclipped the top half of the junction box from the bottom and took it out with the manifold. I couldn't even manage this so in the end managed to unscrew the 3 T25 torx screws holding the junction box to the manifold. Not easy but got there in the end :headbang:
Anyway, on removing the charge pipe from the throttle body I thought things weren't going to look good in the intake judging by the oil in the charge pipe:
Once the manifold was removed, the buildup of carbon was as expected. I won't post every valve but these are indicative:
Two cans of the CRC intake cleaner later and I would say the inlet and valves/stems were about 90-95% better. You could spend hours and hours trying to get every last bit out if you really wanted. I certainly believe the walnut blasting would do a better job, but there's no one in my area offering the service (that I'm aware of), so it's the best I could do.
I'd agree with most people who have done this. The car felt a bit smoother (especially on cold start/idle), a bit more 'torquey' and so on. All based on the scientifically proven 'butt dyno' of course. I do have MHD logs of pulls done today, but I think they're pretty useless as the trans stepped down on acceleration - I really want to see data logged in the same gear. Next time I'm out I'll code the car to not step down at WOT (or wherever it decides to do it).
BMS FMIC and charge pipe on their way, should be here during the week, so looks like next weekend's job. Then I'll try the Stage 1 map again. If all goes well after a while I'll also try the Stage 1+. I have stage 2 maps available but without DP's I'm not sure I should go there yet.
Looking forward to seeing an improvement in IAT's now that I can monitor them with MHD; I've been logging them on the stock FMIC so will hopefully see a good, measureable improvement.
