Does anyone use a Quick-Jack or similar?
True-Blue
Bristol/Bath
Site Supporter
I’m thinking about buying a Quick-Jack or similar, and wondered if we had any forum users with experience of this or a similar system?
I think the entry level Quick-Jack would be enough based on the weight of the Z4, but thought I see if anyone had first hand experience?
Many thanks :thumbsup:
Yeah I have one, I’ve used it to do all sorts on my M3 including gearbox changes, engine removal etc.
Most recently I did the rear brake lines and a suspension refresh in my Z4M.
I’m using the longer version of Quickjack which does, barely, fit between zed’s wheelbase. Oil service, brake jobs, diff oil and more. Quite like them. I usually put some axle stands under the car as well, just to feel more relaxed when crawling under.
Thanks Both,
What do you need to buy in addition to the jack itself, been reading something about it running of 12v & not mains?
@Martyn are you using the smallest version and does it fit the Z4 jacking points easily enough?
There are both 12v and mains versions, plus three sizes, I think: short, long and heavy duty, iirc. Mine leaks tiny amounts of hydraulic oil from the pump while not used and therefore I have placed it in a plastic storage box with wheels, which stores the hoses as well while not in use. The lifts are heavy and need proper holders if stored upright on a wall. I’ll snap some photos.
Brilliant, thank you :thumbsup:
Some photos of them in use. I purchased the long version in order to be able to lift my other cars as well.
6E2DCBAE-C425-4D10-B588-B462AB51E6DE.jpegB5A4A275-2C98-4947-BF6C-F14EC425A3F0.jpeg9E8186EF-CBEE-456D-B03F-B0C97D43674A.jpeg976CCF9B-5DDA-42A0-89BA-4F19D13AD76F.jpeg3C463D39-D592-43A7-A640-03E348B4ECAA.jpeg
That’s brilliant thanks :thumbsup:
I think the shorter version would work for me just fine, but that’s useful thank you. 8)
I assume the 12v could be run of a car battery or something if my garage doesnt have mains?
Tempting : £1200 from COSTCO at present?
Includes: 2 x Jack frames, 2 x Long quick-connect hydraulic hoses (381 cm / 150"), 2 x Short aux. hoses (35cm / 14”), 2 x Quick-mount handles, 4 x Short rubber lifting blocks, 4 x Tall rubber lifting blocks, Mini hydraulic power unit with pendant control.
Yes, the smaller one is £999 and I think it’s would be a perfect size for my garage and Z4’s
Liam22 said:
Don't underestimate the versatility of 3 trolley jacks :wink:
I’m sure in the right hands 3 trolley jacks could be supremely versatile, but I’m not getting any younger and I really like the idea of the ‘ease’ of this system, even if it does come at a price :thumbsup:
Presumably these things are chuffing heavy. Consider the practicality of getting them down off the wall and under the car. I guess one advantage is you can lift your car quite close to a wall where you would not be able to operate a jack.
Sorry to hijack the thread slightly, but would anyone recommend these for use on a gravel driveway?
weegeoff said:
I have just bought mine from Liftmaster ltd for £1122. :D
I thought I was lucky. But because I live on the West Coast of Scotland. I got landed with an extra £30 plus VAT. :x So that comes to £1185 You in the south could get it for £1122.delivered.Here is the web site www.quickjacklift,co.uk
