Redzedfour said:You can have the roof controlled from your keyfob,the dealer won't do it but an indy with right equipment can![]()
aquazi said:mine came from the factory with the roof down enabled from the keyfob.. however i had to get the roof up programmed by an indy.
However i also have the reinhold... so dont think twice... three clicks and walk away!
envy said:aquazi said:mine came from the factory with the roof down enabled from the keyfob.. however i had to get the roof up programmed by an indy.
which indy did you use?
Also where did you get the reinhold from and is it easy to install??![]()
gapTech said:Hi guys.
You can fit yourselves a module that will give you the one touch roof operation, see here.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=290509625752&ssPageName=STRK:MESELX:IT#ht_1101wt_1139
cheers
