Do Z4Ms sit lower at passenger side as standard??
gwatson
 Aberdeenshire
So I fitted Eibach springs last week. The fronts are perfect as is the stance at the rear drivers side (RHD). However, my passenger side sits about 1cm higher (65.8 vs 66.8cm) than the drivers. Is this normal? I only had the car a few days before lowering so not sure how it was before I lowered it so not sure. But I remember my M3 Evo sat higher at the passenger side to offset the addition of a driver in a LHD car.
Great, thanks. I'm not too bothered to be honest. I just wanted to make sure nothing was wrong before I book it in for an alignment.
I will look out for the difference as my car is in for Eibachs fitting :thumbsup:
when i fitted my club sports i adjusted all side even on the perches, once i measured the ride high from side to side was ALL over the place.... to get the car even required all the perches to be set a different places... very annoying and took me about to week to get the car to sit level with constant wheel off / on, drive around, measure and re-adjust situation. what your saying doesn't surprise me at all.
