You can find all aluminium replacement pumps if you search around a bit. A permanent solution as opposed to the half alloy half plastic BMW offeringI have a minor oil pan leak and plan to have it repaired this winter. My car has 90,000 miles on the odometer. It's a 2011 e89 3.0, is there any labor/financial advantage to having the electric water pump and thermostat done at the same time?
The problem is by design, if the plastic impeller fails, plastic should not damage the engine. If an alloy impeller fails it most certainly will.You can find all aluminium replacement pumps if you search around a bit. A permanent solution as opposed to the half alloy half plastic BMW offering
E89 mounts don’t get reported very often fwiwAssume I should do motor mounts at the same time.
If you are doing the work yourself it’s worth noting that if you buy from Autodoc, should the pump fail (as mine did with less than 1000 miles) they can be funny with any warranty claims.I assume the Piersburg water pump is recommended.
Ich habe die Pierburg-Wasserpumpe installiert. It's a solid replacement, better than the original BMW part.I assume the Piersburg water pump is recommended.
Aluminium casing, not impellerThe problem is by design, if the plastic impeller fails, plastic should not damage the engine. If an alloy impeller fails it most certainly will.
