DME Block Plug question
jamiez
 SW London
Guys,
Whilst putting the DME back together after fitting the blue wire for cruise retrofit (to the incorrect pin :headbang:) - i managed to push the big block back onto the DME without the slider/locking thingy being inserted into said connector block.
This means I was left behind with a U shaped piece of plastic doing nothing.
No problem I thought, I’ll just pull the connector block off, re-insert plastic U piece (which helps seat/lock the block to the DME) and all should be fine - WRONG - I can’t seem to budge the block from the DME - it’s as if its locked into place.
Can anybody help? Anybody who has taken "that" block off the DME will hopefully understand what I mean!
Jamie
