Hi.
Whilst this is a massive inconvenience espesialy if its your daily driver its not horrendous or needs to be that costly.
I would have one last go at getting the plug out if that means a long breaker bar and a jack to use the cars weight to either break the plug free of the threads or to pull the threads out with the plug.
If the plug comes free no problem just buy a new plug and probably re tap the sump to clean the threads up.
Or if the threads strip it will need drilling and a helicoil installed to restore the thread.you should remove the sump to do this, but no way should you need a new sump.
The other alternative is to remove the sump take it to an engineering workshop to drill out the sump plug and helicoil the sump.
Which ever way you go you shouldnt need to buy a new sump.
