It might be that the switch is knackered, and it's just co-incidence that it has started to play up after your battery disconnection. Is it possible to try swapping the 2 switches and see whether the fault moves with the switch or stays with the window?tom_ekn said:however going up the first position does nothing! I have to pull it the second position for the window to go up in 'manual' mode as the auto doesn't work.
ZedFourM said:It might be that the switch is knackered, and it's just co-incidence that it has started to play up after your battery disconnection. Is it possible to try swapping the 2 switches and see whether the fault moves with the switch or stays with the window?tom_ekn said:however going up the first position does nothing! I have to pull it the second position for the window to go up in 'manual' mode as the auto doesn't work.
dan425 said:Gah! Semi success... Driver's side is fixed, but not passenger's side!
Sent from my GT-I9100 using Tapatalk 2
dan425 said:Thanks, I'll keep on at it after this weekend once I'm back to the Zed!
dan425 said:VICTORY IS MINE!
Thanks so much for all who gave advice in this thread, especially Dice who had the final method of solving the problem.
Windows are now working properly. Hurrah!
Telstar said:OH MY GOD - Dice you are the greatest person on the earth today. I have been trying to reset the drivers window for a month using every different forum method. I am forever in your debt.
Dice said:dan425 said:Thanks, I'll keep on at it after this weekend once I'm back to the Zed!
Here's how I did it:
1. ignition on (last position before starting but I'm not sure does it really matter...)
2. Press and hold window down. When window reaches the bottom, push the button 3 times (1 elephant, 2 elephant, 3 elephant)
3. Press and hold window up. When window reaches the top, pull the button 3 times (1 elephant, 2 elephant, 3 elephant)
4. then do the 15 cm lowering and closing as I wrote earlier (actually I tested it again and now I lowered it around 3 cm and it worked, so it propably doesn't matter is it 5 cm or 12 cm).
Good luck!
