DISA valve replaced (just in time?)
David-H
 Prees, Shropshire
My "spare" DISA valve arrived this morning, along with a refurb / upgrade kit so after lunch I stripped it, cleaned it, fitted the kit and wondered if I should replace the one on my car or swop it out some time in the future as the car's only done 40,000 miles.
I almost decided to leave it for a while but then saw that the rugby doesn't kick off until 5 o'clock, so decided to get it done before the match.
Just as well I did as when I took out the old unit, the pin was sticking well out and once it was out it more-or-less fell out of the housing all by itself!!
Here are a couple of pics of what it was like:
So, very glad that I decided to get it done I can tell you!! Also well worth checking if you have a 3.0 Zed!
Did mine a couple of years ago. Once I'd read a couple of threads on the subject I couldn't sleep until I'd done it! :headbang:
I've read somewhere, the si engines are not as susceptible to this problem (can't remember where though)
Regards
That pin cant just 'fall out' in the inlet mani - it is pushed against the wall (i checked when i inspected mine). The only way these will likely fail is plastic fatigue/cracking.
Thanks for that bit of comfort. I'm gonna have to take a look at mine. It's done 100k but is absolutely silent around the DISA area so hopefully all will be well.
Wrong they can find their way out its well documented and once you've had it happen to you, your tune will change :thumbsup:
And yes it happened to me on my 330 ci so am speaking from experience, don't leave it to chance if in any doubt change it or fit the I6 upgrade kit :D
K3P0 said:
What happens if the unit fails? is it dangerous, or just poor engine response?
If it fails it's often curtains for your engine, the metal pin that can fall out gets sucked into a combustion chamber :o
Regards
Yikes !!!
How often do you advise owners to check this valve mechanism? Are there any tell tale signs that is about to fail?
"16 Upgrade kit" - what is this and where can I view/buy one?
"16 Upgrade kit" - what is this and where can I view/buy one?[/quote]
eBay £49.99 free p&p or best offer got mine for £45
Search disa valve
Stuart
