UPDATE:
Today, I "upgraded" my DISA unit. TLDR: A big nightmare and possibly ruined a perfectly good DISA unit.
I took the unit out and examined it. It's an OEM part and I had to tug a bit to remove it. All the parts appeared to be working perfectly. I considered just putting it back in and moving on. Ah, what the heck? I have the X8R kit right in front of me. Might as well upgrade, right?
I went to the X8R website... no instructions - all broken links. Went to YT and found their instructions on my own.
Step 1: Remove the pin. Looks super easy on the video, but that pin did NOT want to come out. I spent over an hour trying to pry it out as shown in the instructions, then ultimately was able to get it out with pliers. I can't see how that thing was ever going to fall off into my engine. Oh well...
Step 2: Remove the rotating arm inside the unit. Again, looks super easy on the video. I spent well over 2 hours trying to pull that thing out. You know what? I never was able to pull it out. I had to DRILL it out and even then, the main piece remained inside the original flap. I don't think this unit was ever going to fail... seriously. I nearly gave up, but finally I decided I have to continue.... no turning back now since I don't have a working unit. I did FINALLY get all the old parts out, but with some slight damage to some rubber trim (see below).
Step 3: Put it back together with the new parts and remove the old O ring and put on the new one. Should be easy, right?? Nope. Mine doesn't have an O ring. It has some kind of glued on seal and it wasn't budging either. That took another HOUR to scrape off cleanly. At least putting on the new O ring was super easy.
I was just about to put it back in the engine when I noticed that some of the orange rubber edge trim was peeling. So, peel it off or just leave it alone? I'm sure with all the tugging and wrangling I did, I must have rubbed on accidentally. I don't think it was already like that. (See picture below). I thought about super glueing it, but seemed like a bad idea.... plus with all the oil/grease it probably wouldn't have held. I just left it... for now pending any suggestions you all might have.
Anyway, in the end, it seems like the DISA unit in my 2005 2.5i came from the BMW plant ROCK SOLID. I don't know how old the unit is. It could be original from 2005. Maybe it was replaced once? Or if it's more recent, maybe BMW is designing them better now. Either way, my unit was super solid - I probably should have just left it alone and/or only replaced the O ring.
So, should I be concerned about this? Any suggestions?
