dimensions of the oem wind deflector
Dr-Jon
 Southampton
guys,
can someone with an OEM wind deflector take some measurements for me? I'd like to know the height, width top and width at the bottom.
I'm going to try and make one from perspex to fit.
Height: 18.5cm
Width top: 54.5cm
Width bottom: 43cm
It curves slightly in height from side to side. In the centre, it is 5mm higher at the bottom and 10mm at the top.
Busterboo said:
Height: 8.5cm
Width top: 54.5cm
Width bottom: 43cm
are you sure about the height 8.5cm does not seem tall enough
Dr-Jon said:
Busterboo said:
Height: 8.5cm
Width top: 54.5cm
Width bottom: 43cm
18.5 :)
The end edges curve slightly, too, but only by 2mm. The curve is not central, though. So, if a good fit's needed, some fettling will be, too. :)
Dr-Jon said:
Busterboo said:
Height: 8.5cm
Width top: 54.5cm
Width bottom: 43cm
Lost in translation ,,,,look at msg it says 18.5
sticky said:
Dr-Jon said:
Busterboo said:
Height: 8.5cm
Width top: 54.5cm
Width bottom: 43cm
yes it does now... but it has been edited
