AnubisZed said:Yep, if you have an Automatic the readout for the speed is quite small, this is due to having the gear position displayed by default. If you have a manual then this isn't a problem as the numbers are much bigger![]()
I have the Cheetah mounted on the dash next to the A-pillar and it displays the GPS-calculated speed so it's pretty accurate once you get over about 5mphpvr said:I miss hat in the Z as all the other cars have this, and it is great to see the number in front of you rather than the dial being eiither in fining territory or just outside.
No good for [ref]bigwinn[/ref] and his snail then.PerryGunn said:I have the Cheetah mounted on the dash next to the A-pillar and it displays the GPS-calculated speed so it's pretty accurate once you get over about 5mphpvr said:I miss hat in the Z as all the other cars have this, and it is great to see the number in front of you rather than the dial being eiither in fining territory or just outside.
enuff_zed said:No good for [ref]bigwinn[/ref] and his snail then.PerryGunn said:I have the Cheetah mounted on the dash next to the A-pillar and it displays the GPS-calculated speed so it's pretty accurate once you get over about 5mphpvr said:I miss hat in the Z as all the other cars have this, and it is great to see the number in front of you rather than the dial being eiither in fining territory or just outside.
S Car Go!bigwinn said:enuff_zed said:No good for [ref]bigwinn[/ref] and his snail then.PerryGunn said:I have the Cheetah mounted on the dash next to the A-pillar and it displays the GPS-calculated speed so it's pretty accurate once you get over about 5mph
Three on the bumper this morning
I think the old estate is a snail Alton Towers
