Hoping someone can help with some work required on my 56 plate Z4 - it's a 2.5i manual 6spd model on 106k miles.
I've had it in at my local BMW specialist to have both rear wheel bearings replaced to solve a horrible whirring/squealing noise... I've had a call today to say that, unfortunately, these wheel bearings do still need replacing, but that the diff is also knackered. Apparently there's no drain on these diffs so they didn’t get a sample of the oil but the mechanic could physically feel/hear the bearing.
They've quoted - what is to me - a huge amount of £ for a new OEM BMW diff and said that they wouldn't be comfortable using non-OEM / second hand for the work... From some research it looks like I have two alternative options:
A) full rebuild bearing kits are available for sub £200 online. Finding a garage that’ll be happy to take the old diff apart and fit new bearings etc is the harder part... I don’t have the knowledge/skills/guts/tools to try and attempts this.
B) general notion seems to be that I should seek out a used replacement diff and find somewhere that will swap it for me. Questions are:
- what diff do I need? They all seem to be very specific and I can’t find exactly what model I need for my engine/gearbox setup...
- where do I get one of these diffs? Found a few eBay breakers but not much else
- how much is this likely to cost to swap over?
Praying that this isn’t something that makes the car financially impossible to keep hold of. I only bought it a month ago so very keen to get it fixed but without spending the same amount on it that I paid for it!
Thanks in advance
Thanks in advance
