Diff oil transfer syringe type tool
PDJ
 Worsley Manchester
Today I used said tool and it was very good
Have used a few before and one of them spilt more oil down my arm than went in the diff
I changed the oil in my front diff, transfer box, rear diff and the auto box on my 330d drive
I will post a photo of the box with the part number on tomorrow, thought I had taken one but I did not
I use this type, works fine for refilling, the important thing is to ensure the car is level when you refill so it overflows from the filler hole when its got enough in. Have change diff oils on others cars and found they have been over filled in the past, I think they may have refilled with the rear of the car jacked up or on ramps and ended up over filling.
Photos
The red bit has a 2 way valve so you can vac into then push out in one go
I removed the red bit and filled it that way
the body is cleanable by removing the black bit at the handle end
This ia far the best one so far
