mr wilks said:On the ZM i recently sold i had the passenger side diff seal done , boxes off as you will know , iirc it cost me around £150 parts + labour at my BM indy
VRSteve said:mr wilks said:On the ZM i recently sold i had the passenger side diff seal done , boxes off as you will know , iirc it cost me around £150 parts + labour at my BM indy
Any idea how long it took them??
mr wilks said:VRSteve said:mr wilks said:On the ZM i recently sold i had the passenger side diff seal done , boxes off as you will know , iirc it cost me around £150 parts + labour at my BM indy
Total 2-3 hours i believe / from memory i think the parts were £60? - £70?
VRSteve said:mr wilks said:VRSteve said:Any idea how long it took them??
Thats not so bad.
Thank you!
srhutch said:I think the output seals are a bit easier to do than the input seal. I'm going to check mine before it gets driven again and give it all a good clean up underneath.
srhutch said:I think the issue is getting the pre load right. How hard that is I don’t really know.
VRSteve said:From what I've read, people mark the nut location in respect to the input shaft and return the nut to that position on re-fitting.
VRSteve said:Under the car today taking the back boxes off (sh***y job) and noticed I have a leak from the diff.
It looks like its coming from the input seal.
Has anyone done one, or had one done??
Ta!
Attilio said:VRSteve said:Under the car today taking the back boxes off (sh***y job) and noticed I have a leak from the diff.
Ta!
Hello VRSteve,
Had the same problem recently and got it done by dealer; I understand it takes approx 3 hrs and it ended up being quite expensive because of labour. Can share details via PM if interested.
VRSteve said:Attilio said:VRSteve said:Under the car today taking the back boxes off (sh***y job) and noticed I have a leak from the diff.
Ta!
Hello VRSteve,
If You wouldn't mind dropping me a PM that would be great.
Thank you very much
Attilio said:VRSteve said:Attilio said:Hello VRSteve,
Thank you very much
PM just sent![]()
Just altered my original post as it was misleading , i paid around £150 all done , not parts "+" labour , that should have been parts "&" labour![]()
GuidoK said:VRSteve said:From what I've read, people mark the nut location in respect to the input shaft and return the nut to that position on re-fitting.
That is the normal procedure when you're just changing out the seal.
