Detail or not to detail
Smokin said:
Aliv6 said:
^Eh! Fella you can use Water as lube! Pro's use a very dilute meg's last touch or even shampoo and water. It's all the same, the Megz quick detailer is just a gimic!
Be warned clayin may make the car smooter but it will make it look worse. Then you are supposed to polish. Clayin is just one stage in the detailing process!
Er, I'm not a fella and I'm definitely not cheap. I know for a fact Meg's Quick Detailer cuts bird poop off the car, removing all that uric acid in the process. I'm not a pro and don't pretend to be one, just know what works for me.
Alright...Calm down FFS! If it works for you, good, i'm a believer in sticking to what you know and what works for you. The uric acid so to spk will damage your paint LONG before you manage to get it off with QD, it's almost instant!!!
Relax "Chic"
Ah thats good to know :)
Now I don't feel bad for letting it sit all week till I get round to washing it if all the damage is done in the first hour or so anyway :D (does have several coats of AG HD wax on there so it's hopefully not that bad anyway)
Dave
The more sealant/wax you have the better. it's etch through that first. I had to Wet sand mine in numerous places recently!
If you leave the bird p00 theres a good chance it'll etch into the clearcoat, remove it asap with warm water and dab it with a wet cloth. It'll come off easier and wont damage the clearcoat as easily if you've got some protection on the paint.
