Day running lights
brunswick
New member
I have a 2006 z4M coupe and i tend to leave the lights in the Auto day light running mode. The problem is some times they don't come on when it is getting dark so i have to turn on manually. Any ideas. Also the odometer numbers go dim at the same time ?
The auto lights function uses a sensor to determine if it is dark enough to warrant turning on the headlights automatically for you. If it detects that it is dark enough, like when you go into a tunnel, it puts the headlights on. As it has put the headlights on it also dims the dashboard lights to their night time setting. Sometimes I also find I think it should have put the lights on as it isn't very bright, but obviously the sensor isn't triggered, so I have to manually put them on. This usually occurs on overcast days or coming up to dusk.
An alternative is to leave the headlights set to on. This way you have day time running lights on and when it is starting to get dark or you enter a tunnel your headlights are on. When it is dark your headlights are on as well.
When you leave the car it will turn off the lights as you have removed the ignition key.
If you have an intravee you can change the sensor setting
I found mine too sensitive even in bright daylight they would be on.... Apparently its to frequency of light not the intensity.
I did the above and used my intravee to dial the sensitivity back and mine are on leas often now.
Sent from my iPhone 5s using Tapatalk
