Dashboard bubling
obelix54
 Witney, Oxon
Has anyone every experienced this with their E89 ?
Took the car out of the garage to get it ready for March and noticed the dashboard had a bubble on it.
Unfortunately, it happens on many E89.
Partially re-glueing doesn't help, many have tested it without success.
Hi, I'm a new member - without a Z4 yet :(
So far I've just been learning what to look for in a new-to-me E89, and I hope to buy one this Spring.
I'm a former 128i 'vert owner, and the bubble on the the dash is a familiar issue. Some owners have had success using a hypodermic needle to carefully pierce the dash cover and allow gases to escape. Then with needle still in place, they carefully heat the cover with a hair dryer or heat gun (not TOO hot !). Again with needle in place, they press the cover back down into place, and the hot glue reattaches.
As RobbiZ4 says, this isn't always a success, and even when it is, the vapor-resistant cover material can trap water vapor or other off-gassed solvents from the underlying layers and create the same problem again. My E88's previous owner had fitted a dash cover that gave it a nice fuzzy, matte surface and covered up the bubble - so I never bothered to "fix" it.
Z4Mariner
Have a look at this thread:
nontoxic;27911042 said:
I've had this same issue, but was able to fix it with the syringe method.
I used "3M Neoprene High Performance Contact Adhesive 1357" glue, syringe, and heat gun. First I injected the glue into the bubble, heated up the leather while massaging it with my hand. Soon as the leather shrunk I stopped applying heat to it.
The leathers looks good as new and I can't even find the needle marks. It's held up in Texas sun for few years now.
https://e89.zpost.com/forums/showthread.php?p=27911042#post27911042
Top tip, bookmarking this - cheers Ro :thumbsup: bbie
