Pondrew said:
I was always under the impression that left foot braking was to 'balance' the car better at the limit on a track.
Does DSC not do the same job automatically these days? :?
Hyundai have specifically modifed the N cars to cope with the concept of LFB..
The E89 for sure hasn't..there has beem much discussion on learned forums on how to re-code the DSC for track use..
As stock the DSC fitted to the E89 does a number of clever things for you..
CBC: Cornering Brake Control
CBC is an extension of ABS. CBC enhances driving stability if the brakes are applied when cornering.
Advantage: If the brakes are applied in a corner, optimum brake force distribution ensures optimum tracking stability.
When cornering, even very light braking can shift the axle-load distribution to the left or right so that driving stability is impaired. If required, CBC generates a stabilising load moment when the brakes are applied lightly outside the ABS intervention range.
EBV: Electronic brake force distribution
EBV is a component of ABS and controls the brake force distribution between the front and rear wheels.
Advantage: Regardless of the load state of the vehicle, the best possible braking distance is achieved while driving stability is maintained.
Modern vehicles have relatively large brakes on the rear axle to shorten braking distances. To prevent the rear wheels from being overbraked in certain driving situations, EBV permanently monitors slip. EBV controls rear axle slip in dependence of the front axle.
ASC: Automatic stability control
ASC prevents the wheels from spinning when the vehicle is accelerating.
Advantage: Improved traction. The vehicle remains stable.
If one of the wheels of the drive axle is on a high-grip surface and the other is on a slippery surface, the wheel tending to skid is braked.
ASC also intervenes in the engine control (to reduce the ignition angle, injection quantity, throttle valve setting).
MSR: Engine drag torque control
The drive wheels are able to lock if a lower gear is selected of load is abruptly changed on a slippery road surface.
Engine drag torque control provides protection against locking drive wheels.
Advantage: The drive wheels retain their lateral stability in overrun mode.
The wheel speed sensors tell MSR as soon as the wheels are about to lock. MSR then briefly reduces the engine's drag torque by opening the throttle slightly.
DBC: Dynamic brake control
DBC supports the driver in emergency braking situations. It does this by automatically increasing braking pressure when the brake pedal is not depressed with sufficient force.
Advantage: Shortest possible braking distances in emergency braking situations by achieving ABS regulation on all four wheels.
The brake pedal is frequently not depressed strongly enough in emergency braking situations. The ABS feedback control range is not reached (or not on all 4 wheels).
The return pump increases the brake pressure until ABS regulation is activated:
If the brake pedal is depressed quickly with insufficient pedal pressure (recognised from the signal from the brake pressure sensors)
If the brake pedal is depressed slowly and then with greater braking deceleration than necessary (recognised from the signal from the brake pressure sensors), when both front wheels have reached the ABS control threshold.
Example of a typical situation:
The traffic slows, making light braking necessary at first, but then demands as short a stopping distance as possible.
Brake Standby through pre-tensioning of the brakes in an emergency
Pre-tensioning the brakes shortens the brakes' response time.
If the accelerator pedal is rapidly released (accelerator pedal angle), the brakes are immediately pretensioned. DSC generates a low braking pressure through the “analogised” solenoid valves, without creating any measurable deceleration of the vehicle. The working clearance between the brake pads and brake disks is equalised. If the brakes are not applied within a certain time, this preliminary brake pressure is cancelled. The early pre-tensioning of the brake pads is active at road speeds greater than 70 km/h.
Fading compensation
Fading means: braking effect deteriorates as a result of high brake-disc temperatures.
If fading is detected, DSC reacts by increasing the brake pressure above that specified by the driver.
At very high brake-disc temperatures, fading compensation is indicated by the following:
General brake warning lamp lighting up yellow
Check-Control symbol in LCD display in instrument cluster lighting up yellow
DSC detects fading as follows: DSC compares the current vehicle deceleration with a nominal value based on the current brake pressure. DSC increases brake pressure until the nominal deceleration is achieved or until all wheels are subject to ABS control. The process is ended when the brake pedal is no longer depressed or when the speed drops below a certain threshold.
Thats a non exhaustive list but those that matter on fast use /track..
