Afternoon all, I have a slight issue with bank 1 not firing. Background: I think I might have had a bad batch of fuel (unconfirmed).......the car started to run badly and jittery. It has now proceeded to only fire on cylinders 4-5-6 (bank 2). Prior to discovering it was bank 1 not working I changed the spark plugs for NGK ones as I had a brand new set waiting to go in.
The car will start but only runs on the rear bank. I had disconnected coil packs 1-2-3 and nothing changed. The coil packs are not particularly old either.
Not a lot of fuel had been put in but it did get run low. I can't believe that it's an injector issue as just the front bank failing on a common rail seems a little hard to believe.
Fresh fuel has been added.
Is the front bank controlled by a separate controller or have a separate fuse? I'm at a bit of a lose now........any help would be greatly appreciated
