CVM: Drive, cowl panel, safety catch - Help!
This thread came straight up when I Googled it. I can strongly recommend Google as a primary source of info :wink:
https://z4-forum.com/forum/viewtopic.php?t=95698
Angelsambrook - How did you finally fix the problem? My wife's beloved Z is having the same problem. The roof latches close and then reverse without latching and the lift motor doesn't engage. I replaced it and moved it to the trunk and repaired kinked wires in the roof loom. At a loss how to proceed. Any ideas? Thanks.
0x23220040 40 Drive,cowl panel,current too high when opening safety catch
0x23220041 41 Drive,cowl panel,current too high when closing safety catch
Jan, that member hasn’t been active for over two years so you’re not likely to get a response but hopefully someone else will pop along and maybe able to help :thumbsup:
Oh, and hello and welcome
Thanks, Andy, I hope so. As these Z's age, I guess the number of active folks dwindles, but we never run out of things to repair!
