Buckley06 said:Sad times.
I thought I would have had more people inbox me.
Please remember the font and shape can be changed.
MefiEcosse said:Do you know what these will weigh?
check out the images in the for sale section. It looks very much like the stormworks in shape and style except I think better as it has Z4 engraved on the top instead of M. If the dimensions are the same, the weight will be the same. £75 or £32...its a no brainer really.LittleZ4 said:Do we know what they will look like? Will it be the same as the storm? Or a different style. I'm interested.
Unless your peddling an ///MDavz said:check out the images in the for sale section. It looks very much like the stormworks in shape and style except I think better as it has Z4 engraved on the top instead of M. If the dimensions are the same, the weight will be the same. £75 or £32...its a no brainer really.LittleZ4 said:Do we know what they will look like? Will it be the same as the storm? Or a different style. I'm interested.
Chris_D said:Could be interested.
What surface texture/finish are you thinking about? Would be nice to have a bright or stain polish; 1P/2P or 1K/2K maybe....
You should be able to calculate weight if you're using solid edge.
Otherwise port to solidworks and do it that way.
thanatu55 said:Anyway I'm not hating, I said it was a good idea already and would be in if I didn't already have mine sorted (plus I suggested the Storm Motorwerks model... not sure if it was already settled upon beforehand though), it's just a little trivial to think/claim that if you just copy a shape then they're the same. Still, wouldn't mind a Z4 logo on mine![]()
Buckley06 said:Chris_D said:Could be interested.
Hi it will just be a standard turned finish, I thought about using scotch bright but I think straight off the lathe is better.
I thought the weight was shown highlighted in blue on my picture?
I only dabble in design or and tend to stay away from the physics.
If you have better use of the software I can send a STP file over and you could double check for me.
Buckley06 said:Hey, I went with the stormweks style because of your input.
I just don't have the time or the software capability to calculate the exact weight ratio.
I have a stubby gear knob and took the sizes from that.
If you have a vernier I could do with a OD measurementand the length.
And maybe the hole for the stick to go in
