Custom Cruise Control Loom
Darkangelv2 said:
Or £15 on Ebay if you're really lucky :P :poke:
Very good buy :thumbsup:
I managed to pick mine up for £45 including slip ring, indicator and wipers stalks.
More bits sitting in a box :lol:
That was what mine was! The left stalk had snapped so obviously felt it was now more or less worthless.
Hi guys, do we have a part number for the cruise control stalk to help with the searches for deals :) ? Is it different between facelift(2006) and before that ? Thank you.
61316940989 - stalk part no :thumbsup:
Hi Steve,
Putting this here rather than a PM, to see what interest there is.
I’ve been looking through the instructions and have a few questions, also want to offer to help if I can.
I’d consider myself fairly handy with a lot of jobs, but playing with the electrics just makes me that little more wary (cutting wires or not).
With the fact you’ve sent two sets of instructions which contain different engines/different years, looking through some of the instructions just leaves me with a bit of a question mark over the clarity of some of it. (Don’t get me wrong, you’re doing this for £20, I appreciate it a lot!)
It’s worth saying that I’ve not attempted anything so far, it’s just on first review - maybe it all becomes clear when you start, but I don’t want to start taking stuff apart before I know I can finish it.
I do think the instructions could be clearer for some of us non-electrical savvy folk who know they have competency in DIY jobs, but just that some of this looks a little confusing.
I have the full adobe acrobat software, so can manipulate the two instruction manuals into one. I can also put your instruction parts in between the steps of the BMW pages (which I think is needed) plus remove the unnecessary extra pages that are in there and just taking up space/ cause confusion.
I could make these for different models, different years if needed.
It may just be me being a fanny, but I got the stalk yesterday, opened the two instructions and was a little confused and now feel the need to go to a friend of mine who I hope will know what to do.
My main confusion is the order in which you go from one doc to another, there’s text on some pages which is in reference to the pic on the following page - but you can work that out quickly enough I know.
Random questions that I have are:
Step 1 Disconnect the battery. What are the consequences of disconnecting the battery? I don’t have any books, so will the radio work afterwards?
Step 5 Feed the blue wire over to the glovebox. Removing the panel underneath the A/C controls helps.
:D Thats quite vague, from the right hand air vent to the glovebox is a fair distance - any extra detail here would help - or pics!?
Is Page 4 in your manual, the first time that we then look at the BMW instructions, and if so, I assume we go straight to page 11? If so, that makes the rest of the document redundant (ref my offer to cut down earlier)
I have other questions, but don’t want to ramble on more than I have.
Again, VERY pleased that you’ve done all this - not a criticism at all, just an offer to help this good cause for others who may find themselves in the same boat. :tumbleweed:
Not a problem.
I didn’t see the point in completely re writing the bmw instructions. Most of it is applicable except for the Ecu connection and the LCM connection, which is where mine come in.
I’ll drop you a pm with my mobile on so you can give me a shout if you have any issues. TBH I think when you start it will all become clear.
Regarding the battery, you must disconnect this before touching anything on the electrical side of this mod. Only thing you will have to reset is your clock and windows for one touch up.
HyperGrade said:
Hi Steve,
Don't know how much you've read around the forum on this topic but before Steve developed 'his loom' lots of members fitted them by cutting wires or using scotch locks on looms from BMW. Steve's loom is very much plug and play by comparison. However the cabling routes are; as far as I can tell, the same. If you search the old threads they go into detail about how to route the cable and remove/replace trim which is in the way. Might be worth a look :thumbsup:
Only the two footwell trims need to come off, I then use a nut on some string to drop through the bulkhead hole behind the glovebox and pull the wire up again. The cable can be secured to the main loom that runs along the bulkhead with ties. It helps to have someone else on the other side when feeding through from one footwell to the other.
Bit of wire does the job for me. :wink:
I don't even remove the LCM now, just remove the plug blind, bit tight but done three this way now. Saves removing the trim which can be hard to get off without damaging.
Hi Steve. CC fitted today. Everything fitted as advised and working as it should. Great to have CC up and running on my recent addition. Thanks very much for doing this Steve. Very much appreciated. :thumbsup:
Thanks for the updates :thumbsup:
I'll have more made up over the weekend so will have spares, which takes some pressure off going forward :lol:
This is my DME unit on M54 srhutch, any ideas Steve ?
Hi srhutch,,
Thanks for the info & links ,, I’m on nightshifts this weekend but will get straight on with instillation on my days off 👍
