Cruise control
Singapore stag
 London West
Hi, Would the facelift 2.5I Se have the wiring to retro fit cruise control? I am a bit confused, I read on one of the post earlier that only the pre 2004 have the wiring and a mark on the cowl for the stalk.
Rgs
No, you'll need to add the correct wiring harness - that post you read is correct, BMW stopped pre-wiring a few bits and pieces sometime in 2004.
Lots of people have done it though - find a guide and good luck :thumbsup:
No, but if you contact "srhutch" he'll make up the section of loom you will need for sensible money. :thumbsup:
I think they all have the outline on the inside of the lower half of the steering column cowl showing what you need to remove - or just remove it to check!
I had a look at this post, but cannot seem to access the pictures...
viewtopic.php?f=25&t=14699&hilit=retrof ... se+control
