As in a previous post, I mentioned the z4 I'm looking to buy has a few 'niggles' which need tidying. The main one is the Plastic strip at the bottom of the windscreen (below where the wipers park) is loose from the drivers side corner to middle of the screen. Question is, is this a common fault on these cars or I'm thinking if the windscreen has ever been replaced that someone was a bit heavy handed meaning the plastic is about 5mm off the glass. Is this easily fixed and more importantly if water is running down the windscreen and under the gap, is it likely to be causing water ingress into the car unnoticed causing 'hidden' damage.
Also the front towing ring and bumber cover are missing - are they expensive to replace?
Any help appreciated.
