Couple of issues after battery disconnect
  • Start date Start date
Finally got hold of INPA and had a read/clear of codes.
Apologies for the mix of german/english - I've translated the important bits (I think)
First code which will explain the DSC light. This code will not clear. I'll need to work my way around INPA to try and reset the steering angle.
Date: 23.04.2018 21:46:55 ECU: DSC_MK60 JobStatus: OKAY Variant: DSC_MK60-------------------------------------------------------------
RESULT: 1 error in error memory !-------------------------------------------------------------
5E40 Steering angle sensor signal implausible, offset
Error counter: 4 Logistic counter: 40
Mileage 655350 km Fahrzeuggeschwindigkeit 0.00 km/h Bremslichtschalter 0.00 0/1 Bremsfluessigkeitsschalter 0.00 0/1 ASC/DSC_aktiv (Tasterfunktion) 1.00 0/1 Bremsdruck erkannt 0.00 0/1 ABS-Regelung 0.00 0/1 ASC-Regelung (BMR) 0.00 0/1 ASC-Regelung (AMR) 0.00 0/1 GMR-Regelung (GMR) 0.00 0/1 GMR-Regelung (MMR) 0.00 0/1 CBC-Regelung 0.00 0/1 MSR-Regelung 0.00 0/1 TDR-Regelung 0.00 0/1 SDR-Regelung 0.00 0/1 DBC-Regelung 0.00 0/1 RTA aktiv 1.00 0/1 Run-Up Mode 1.00 0/1
No matching error symptom test conditions satisfies errors currently present and already saved errors would cause the lighting of a warning light
Error code: 5E 40 E0 04 28 FF FF 00 0A 00 0C =============================================================
Next up from EPS...
Date: 23.04.2018 21:43:17 ECU: EPS_85_2 JobStatus: OKAY Variant: EPS_85_2-------------------------------------------------------------
6125 Error code 33: Lenkwinkelkorrektur
Error counter: 1
Mileage 105424 km Temperatur FET 26.00 Grad Spannung nach Relais 11.57 Volt Batteriespannung (Klemme 30) 11.49 Volt gemessene Temperatur FET 26.00 Grad Flag Zündung ein 1.00 0/1
No matching error symptom test conditions does not currently exist, but already saved errors would not cause a warning light to light up type No. 6: Too high
Error code: 61 25 20 06 01 33 7A 00 60 01 D0 01 CD 00 60 00 01 ============================================================
This was the full report. Again I've translated the error messages so they won't be perfect English. There's a couple that look related to an open/close button. I wonder if that's because GapTech is installed?
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 04/23/18 21:33:40 ECU: D_STVR2 JobStatus: --- - API-Job FsLesen: job status error - API-Job FsLesen: job status error
============================================================= Variant: CVM_IV 5 Error in error memory Error registration 1 : 0x0013: Control button ' Close ' permanently on GND <<<<!!! Error accurances: 10 Aussentemperatur 19.00 Grad C
sporadischer Fehler Error code: 13 0A 13
------------------------------------------------------------------------------------ Error registration 2 : 0x0021: VSW 4.2, undefinierter voltage range <<<<!!! Error accurances: 11 Aussentemperatur 22.00 Grad C
sporadischer Fehler Error code: 21 0B 16
------------------------------------------------------------------------------------ Error registration 3 : 0x0024: VSW V_ABGEL, undefinierter voltage range <<<<!!! Error accurances: 6 Aussentemperatur 22.00 Grad C
sporadischer Fehler Error code: 24 06 16
------------------------------------------------------------------------------------ Error registration 4 : 0x0012: Control button ' open ' permanently on GND <<<<!!! Error accurances: 8 Aussentemperatur 16.00 Grad C
sporadischer Fehler Error code: 12 08 10
------------------------------------------------------------------------------------ Error registration 5 : 0x0064: Canopy does not go on <<<<!!! Error accurances: 3 Aussentemperatur 4.00 Grad C
sporadischer Fehler Error code: 64 03 04
------------------------------------------------------------------------------------==================================================================================== Variant: LSZ_2 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: D_0066 -1 Error in error memory ==================================================================================== Variant: D_00E8 -1 Error in error memory ==================================================================================== Variant: D_0060 -1 Error in error memory ==================================================================================== Variant: EWS3 2 Error in error memory Error registration 1 : 0x000F: Power-On-Reset <<<<!!! Error accurances: 31
statischer Fehler Error code: 0F 3F
Error registration 2 : 0x000E: DME-Wechselcode XOR-Fehler <<<<!!! Error accurances: 4
sporadischer Fehler Error code: 0E 04
------------------------------------------------------------------------------------==================================================================================== Variant: LWS5_1B >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: ZKE5_S12 4 Error in error memory Error registration 1 : 0x000E: Window lifter: Interruption of clamping protection strip or destandardization/error EKS-Electronics Beifahrertuer <<<<!!! Error accurances: 17
sporadischer Fehler Error code: 0E 11
------------------------------------------------------------------------------------ Error registration 2 : 0x000D: Window lifter: Interruption of clamping protection strip or destandardization/error EKS-Electronics Fahrertuer <<<<!!! Error accurances: 10
sporadischer Fehler Error code: 0D 0A
------------------------------------------------------------------------------------ Error registration 3 : 0x0033: Wiper: Blocked or Rueckstellkontakt <<<<!!! Error accurances: 3
sporadischer Fehler Error code: 33 03
------------------------------------------------------------------------------------ Error registration 4 : 0x0041: Diebstahlwarnanlage: Neigungsgeber <<<<!!! Error accurances: 3
sporadischer Fehler Error code: 41 03
------------------------------------------------------------------------------------==================================================================================== Variant: SZM46 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: KOMBI85 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: IHKA85 >>>>>>>>>> No error found <<<<<<<<<<< ==================================================================================== Variant: D_0068 -1 Error in error memory ==================================================================================== Variant: D_006A -1 Error in error memory ==================================================================================== Variant: D_00C8 -1 Error in error memory ==================================================================================== Variant: D_00F0 -1 Error in error memory ==================================================================================== Variant: D_00ED -1 Error in error memory ==================================================================================== Variant: D_003B -1 Error in error memory ==================================================================================== Variant: D_0048 -1 Error in error memory ==================================================================================== Variant: D_007F -1 Error in error memory ==================================================================================== Variant: D_00BB -1 Error in error memory ==================================================================================== Variant: D_0072 -1 Error in error memory ==================================================================================== Variant: D_00DA -1 Error in error memory ====================================================================================
############################################################### This content will stored temporary temporär in ..\inpa\sgdat\na_fs.tmp #######################################################
Just about all error codes cleared, but lights still on dash. I believe sorting the steering angle may sort that. Also worth mentioning that when accessing TPMS through INPA it errored saying there was no response from the control module.
Thanks,
Greg
So, yeah...
