coupe window probs - sitting outside the seal
steelmind
 Weybridge, Surrey
Hi,
On the coupes (not sure about convertables) the window dips a bit when you open the door, then when you close it, it rises back up to sit within the seal under the roof.
The prob is a few times (both driver and passenger) i've closed the door and the window is sat outside the seal and therefore with a large open gap :x
I have the auto door locking function activated for when i pull away, and when i park up you have to pull the internal door handle twice, once to unlock and once more to open the door. Its at this point on the second time you pull the handle that the window dips a bit, but mine seems faulty.
the only way to put it right is to get back in the car to open the window then close it again.
Any one else got this problem, is it something i am doing wrong, or is this a fault?
alan
Had this one or twice on the roadster, try the window reset procedure a quick search on here and you should find it.
