Coupe niggles
speed12
Well, after 6 months of ownership and 5 months of paying the insured warranty (Modial), I had enough of a few niggly noises.
I took my coupe into Knights BMW Stoke n Trent and told them the following;
1.) Severe road noise between 40 and 60 mph
2.) Engine whirring sound/ bearing noise when driving in 1st and 2nd gear at slow speeds.
3.) Gearbox/ clutch rattle at idle in neutral - I beleive this is common and reportedly normal and no issue, however I thought I would see what they said.
After they did their road test (which i was not invited to attend), they confirmed the following;
1.) Road noise is due to tyres which are heavily unevenly worn - I guessed as much as my MOT picked this up. Gives me an excuse to ditch the run flats anyway.
2.) Enginer whirring sound - They beleive this is the alternator but it needs booking in for diagnosing.
3.) No comments (and i forgot to ask before leaving).
4.) They reported that the steering control arms were due replacement.
Now, I have the fully comprehsive Modial insurance warranty, so I feel I should be ok with the alternator, though my fear is that after spending a fortune on dealer diagnoses they say no fault found.
Regarding the control arms, they have quoted £135 for labour and £113.31 for parts (part number B31.12.6.783.376 I beleive?). Does anyone think it is worth trying to get these on the warranty? or will they simply play the wear and tear card despite the car only being 5 years old and 49K miles?
Assuming i do replace the control arms, is this an easy DIY job? anyone got any ball park costs from indy's?
Might try and email Mondial about the misted fog lights too, as I beleive some people have had success on here by claiming it was caused by corrosion and not seal failure?
Control arms will be wear and tear so no joy, as I would say for Fog Lights.
Best of finding an Indi for the arms.
Re: item 3, I've just had the flywheel replaced under warranty on my 3.0si coupe because of a noise when the engine was idling in neutral. The noise would disappear when the clutch pedal was depressed about half way. My initial thought was a gearbox bearing but the noise hasn't reappeared since the flywheel was renewed.
Regards
Grumps
Regards
Grumps
I didn't think the flywheel was covered under used car warranty.
Must get mine looked at.
I thought I read on here and a few other BMW forums that a bit of a rattle at idle whilst in neatral was fairly common with the 3.0si's?
Will have to look at the small print of the Mondial Warranty, not sure if the flywheel is covered
Yeah let us know how you get on.
DPG said:
Regards
Grumps
Had my Dual Mass Flywheel replaced under Mondial warranty when Zed was 7yo.
Sent from my iPad using Tapatalk HD
