Coupe boot lid adjustment
Attilio
 Dublin
Hi,
I noticed there is a little play on the left side of the boot lid of my Coupe if I press down on its left side; the right side is nice and tight. I was wondering if there is a way to adjust the rubber stoppers to eliminate the play - and most importantly the noise that derives from it when going over rough ground.
I know it may sound a bit OCD but once I spot an issue I get a bit obsessive :P
Thanks for your help!
The rubber feet/stoppers can be adjusted. Rotate counterclockwise to wind them out. I'd suggest to screw both in fully and then wind each out a bit at a time to dial in the adjustment and get the lower lip of the tailgate parallel the the bumper. Also, check the Torx nuts holding the tailgate hinges to the body. I had to tighten mine a bit.
Hello Gummi,
Thanks a lot for your suggestions, will try over the weekend and let you know how I got on.
:thumbsup:
