Correct PSI 18" Bridgestone Run Flats
Hi Nigel, depends on tyre size
EDIT - if you're on
225/40 18 - manual says 33
255/35 18 - manual says 36
There should be a sticker inside the door with details.
33psi front
36psi rear
A few members run different pressures. THe above pressures will ok for Bridgestone Potenza run flats... :thumbsup:
