First, have you done the 'mayonnaise test'? Check to see if the oil cap is clean and not messed up with what looks like mayo?birdy_z4 said:Thanks for the comments, hmm ok any advise on leak detection techniques
Busterboo said:First, have you done the 'mayonnaise test'? Check to see if the oil cap is clean and not messed up with what looks like mayo?birdy_z4 said:Thanks for the comments, hmm ok any advise on leak detection techniques
Jasonn said:I've bought that uv tracer dye probably lost about an egg cups worth over the past year but can't get a uv stain to show
Good!birdy_z4 said:Well no mayonnaise water contamination in the oil filler cap
Onto more detective work
Busterboo said:Good!birdy_z4 said:Well no mayonnaise water contamination in the oil filler cap
The next usual suspect is the water pump, of course. (In my experience, 'the mechanic's holiday fund': "You've got a bit of a leak from the water pump. It's only damp now, but you never know. Better safe than sorry" is the standard script.)
p.s. How much water are you losing?
I suspect both these answers are correct:birdy_z4 said:Not checked it since last year when put the car under cover :wink:
Done a couple of 300 miles round trips in the last month and would say maybe a small cup from being full potentially
Busterboo said:I suspect both these answers are correct:birdy_z4 said:Not checked it since last year when put the car under cover :wink:
1 That's how much the engine's needed to wet its whistle to shout, 'Drive me ... drive me ... more often!' But nobody's been listening.
Ha hadidn’t wanna get it dirty
2 So, none at all, really. :wink:
birdy_z4 said:Well now it’s rested leaking even more looks like radiator gone
