Coolant Recommendations?
javis20
 Hershey, PA USA
My previous VW's always had factory coolant that wasn't compatible with anything else... G13 and so forth. Is there a recommended coolant for BMW's? Is there anything special about there factory coolant?
The BMW coolant can be mixed with harder tap water than most. Comma G48 is also an equivalent fluid that BMW approve.
I use the oem bmw stuff, simply because I know that's what was already in there and I don't think you are supposed to mix coolants.
Cost a tenner for 1.5 litres which mixes 50:50 with water.
