Greetings to all!
My 2003 z4 has been leaking coolant for quite awhile. I took it to repair shop and they replaced the cooling hose flange, the expansion tank, and the transmission oil cooler thermostat. A month later, the car was back to the shop as it was still leaking coolant. This time they replaced the upper radiator hose with the bleeder valve. However, after I spent almost $1000 for repairs, the leak is still there.
I’m a woman and not a mechanic by any means, but today I detach the radiator/engine cooling panel shroud and found that the upper radiator hose outlet (I’m not sure if this is the correct part name so I’m attaching a picture)
wis full with coolant.
My question is: Is this normal, as I didn’t see anything like this on the videos I watched.
wis full with coolant. My question is: Is this normal, as I didn’t see anything like this on the videos I watched.
