Coolant leak, gaskets?
domsz4
Veteran
So the car that just keeps giving has once more given.
Water was dripping but is now frankly pissing out more than my potty training toddler. I thought "ah cracked expansion tank again" but no. It’s coming from either the mounting bracket for the bottle or the bottom hose can’t quite see as it gushes out.
I’ve had the rad, expansion bottle, mounting bracket and all hoses off the car, all have been cleaned, no signs of cracks or any missing bits.
Anyone else had this? Can you buy the gaskets separately
I feel your pain, I've recently changed expansion tank, thermostat, and coolant and had the car leak free for a month and just noticed another leak now coming from the same area, mine looks to be coming from the radiator itself a very small pinhole leak either that or where the the bracket clips onto the radiator.
From my experience if your leaking alot of coolant it should be straightforward to see where it's coming from, I'm both my cases the leaks only presented themselves when the car was thoroughly warmed up and been pushed hard, idling on the drive and you wouldn't even know I had a leak
Oh you can see it, no ambiguity al at its pissing out. Problem is there’s 2 connections on the tank and 1 for the lower hose. The water is just streaming off the hose connector so you can’t see which one it’s coming from. Tank and hose have no damage. Seems daft you can’t replace the ring. Tbf it was dark by this point and inspection lights are only so good. I’ll have a better look in the daylight.
