ionofchios
Just been flushing coolant on my manual e85 3.0si (N52). This is the first time I’ve done this, and I was following a how-to that recommended not removing the block drain plug, since it is alloy and one-use only, and, worse, apparently block threads can even get damaged. Anyways, my objective was to flush out the whole system and replace the strange orange stuff that was in it with BMW blue.
I removed the 2 radiator-related blue plugs and drained everything out. Then filled with distilled watered and did the trick where you turn ignition to stage 2, turn up heater and press accelerator for 10 seconds, which puts the water pump into some burping/service cycle. Left it for ten minutes, topping up with distilled as needed, all that stuff, and it squirted through quite a few times. I did this flush procedure 2 or 3 times in total, going through about 15 L of distilled.
After that, I drained it again from the blue plugs, then made my mistake
Somehow, I had remembered that the capacity of the cooling system is 10 L, so I tried to put 5 L of straight coolant in, figuring that there was about 5 L of pretty much pure distilled water left in the system. But, I only managed to get to about 4.75 L of coolant in before it was full. Then I had a read around, and found that the capacity is in fact 8.2 L - though there does seem to be some lack of concensus on this matter.
So, what should I do now? Is the ratio that important? According to my calculations, I’ve got about 4.6 L of coolant and 3.6 L of distilled, assuming all the orange stuff is basically gone.
Also, does running the water pump with the above procedure actually cycle the whole system, including the block? Am a bit worried that I’ve only flushed half the system.
All in all, seems like it would have been easier to remove the block plug and replace with a new one, then fill with actual 50:50 mix.
