Coolant does not boil at 55 deg C, where did you get this info from??
In a kettle it will boil at 100 deg C
In a pressurised environment (cooling system) the boiling point is raised, this is why the system is pressurised, otherwise if you drove up a mountain the drop in atmospheric pressure would cause the coolant to boil at less than 100 deg C.
Water boils at 100 °C (212 °F) at sea level, but at 93.4 °C (200.1 °F) at 1,905 metres (6,250 ft) altitude.
At 2 bar pressure (average-ish for a cooling system) water boils at around 120 deg C.
