Bluebluemooner
Bled the coolant system on my e85 after fitting a hella expansion tank after the old one developed a pinhole leak .
I've followed the procedure with nose up on ramps heater sytem running set to hot until the fluid comes out of the bleed hole free of bubbles.
My question is what now? All the guides I've read including tis say reinstall the bleed screw then nothing else. However at this point the fluid level is close to the neck of the tank and showing overfull. I can't believe this is right so have syphoned off some fluid before running but is this correct? Thanks in advance Andy
