Coolant bleed Issues... 2.0 E85
tartan-ninja
West Scotland
Hi...I am a bit lost to be honest... the alloy covered pipe on the left hand side of the block had snapped at the block side... so was replaced, thing is now I dont seem to be able to bleed the system properly.
I have replaced the coolant with the BMW 50/50 mix and still cannot seem to get the air out or the heaters to warm..have Her nose up a bit to help have the bleed screw half way to allow, marked it with white paint to spot where its at.... car runs to hot and fan comes on and off but gauge is still in normal, i get it to flow from the bleed screw..then it just stops flowing and I get steam, it I squeeze bottom or top pipe I can get some out of the bleed screw.. tried it with both cap on and off... still no result...bottom pipe seems cool all the time, but top heats and so does the one out of the block...
Never had any coolant loss issues before the pipe went or warnings....
Any Ideas?
Regards to all
Jim
