Hey Everyone. I got an 2008 E85 last summer. It was great for a while, but then the top stopped working. After a lot of research here and elsewhere, I was able to successfully get a new pump (kept the existing motor) installed and moved into the trunk. I used the method of going in through the trunk rather than removing the top. I got it all working once more and was in bliss again. But, after a few weeks, the top stopped working again. I had remembered reading that the pipes may have gotten air in them and after running the top, the fluid could drain to fill the pipes and then stop working. I added more hydraulic fluid and it worked again...for one or two cycles. So, I added more fluid. At one point, I added fluid and just sat in the car and put the top up and down about 8 times to make sure the lines should be fully cleared of any air. That worked fine. But a few days later, it stopped working again. Now, if I add more fluid and put the top down, it won't go back up. I check and the fluid level has declined a decent amount. However, I can't see where the fluid is even going. There is nothing draining from the car and I can't use the top because it won't work longer than one trip open but not back closed.
I'm a total noob to all of this and car maintenance in general. I know just enough to get myself into these kinds of problems and feel like I can and should take care of things myself
Any thoughts, help or suggestions would be greatly appreciated. Where is the fluid going? Is there simple things I can do to try to get it working? Is there an actual leak somewhere that I need to track down and how? Or, is it something simpler like just filling the fluid up to the very top (I fill it up to about halfway full in the white semi-transparent canister at the top of the pump/motor? Any diagnostics or other things I can try?
Hoping you all can help me here. Would love to get some enjoyment out of it during these last couple months of summer.
Cheers all!
Cheers all!
