Well today I decided to remove the hydraulic lift motor with the through trunk method. Worst part by far is getting the bottom bucket out. Major major pita! You must pry it out until the tie wraps and mount break. I actually partly cut mine with tin snips.
Anyway the motor is shot. All rusted and won’t work. Anyone use the aftermarket motor and pump assembly? eBay has plenty of high priced oem used and untested.
