Convertible top indicator light blinks...whats it mean?
BTFU23
New member
As posted before the motor doesnt work on the z4 so I have been using it as a manual top. The buttons that operate the top blink and every so often when I press it, the top will unlatch and the windows will go down. Other times the light is off and nothing works. What should I fix/check, for it to work all the time so I dont have to use an allen bit to unlatch the top?
surely you don't need two topics on the same issue posted within 3 minutes?!
http://www.z4-forum.com/forum/viewtopic.php?f=3&t=17861
You'll now get responses in two places on a question that might have already answered in full elsewhere.
edit: use the search function, but does this help? -> http://www.z4-forum.com/forum/viewtopic.php?f=3&t=16625&p=241836&hilit=roof+cable#p241836
sounds like a similar thing to what you describe in your other thread?
Ill keep this in mind...first time. Im hoping that I just need to get fluid or a used motor and that would solve the whole issue.
There's a whole how-to from Shipkiller on replacing the motor yourself if you are feeling brave ;)
edit: http://www.z4-forum.com/forum/viewtopic.php?f=32&t=10190
Yeah I thought about that, I just dont want to buy a motor and have it be something totally different.
