Continuous Rattle Anti-noise Prevention CRAP
flybobbie
Elite
 Stourbridge
Well roof down a blumin rattle from top of window shield.
Years ago i fitted rubber stickers where sun visors rub on trim.
Now new rattle.
So removed the black window trim. Stuck down all wires with foil tape.
I run a length of black insulation tape where black plastic sit just below roof rubber.
And what might be the cause of the rattle the spring clips inside each sun visor pivot shaft.
There is inside a bent oval-ish clip that holds visor up or down.
In some positions it's loose and rattles, so wedged some insulation tape around it...
Rattles all gone. :D
Now i can hear the blades in the air vents slightly rattle. :x
Might take out and try blob of something on the end of each blade where it pivots where can't be seen.
Have some semi drying black drain pipe sealant.
This'll sort that out... :thumbsup:
Butt Plugs… considerate to get one for the passenger too, I’m guessing this will distract the occupants and they won’t notice the rattles :censored:
