stal023 said:Here is what I am finding so far:
- Water pump seems to be a common issue ~$200 part
- Window Regulator ~$200 part
- headlight condensation
- Top motor is in a crap location; new $175-200 and relocate the motor
- Disa Valve, this is just in the M52 and not N52. How do you know which engine is in which vehicle?
What am I missing?
Zedebee said:stal023 wrote: ↑Thu Apr 15, 2021 6:08 pm
What am I missing?
Electric water pump I think is a post facelift issue only (someone tell me if I’m wrong)
Headlight condensation is post-facelift only
Motor relocation is roadster only (obvs)
M54 is pre-facelift, N52 is post-facelift. Google pictures, they look different.
M54 can have problems with CCV, particularly in cold climates or running short journeys.
Corroded brake lines are often a problem (all models, it’s a symptom of wet weather and age).
Suspension bushes wear out with mileage.
Vanos solenoids.
The 6 cylinder engine is strong and rarely goes wrong if properly looked after. It can be prone to oil leaks, but these don’t tend to be terminal.
All the above relates to the E85, but also the earlier E89 models fitted with the N52 engine. Good luck finding a nice car.
Pre facelift has really nice looking rear lights. On the facelift they melted...... :wink:Zedebee said:Yes, facelift in 2006 with new engine, when the E86 (Coupe) was launched. You can easily tell the difference from the front. Pre facelift has the small round fog lights, post facelift has the rectangular ones, usually full of muck and water.
stal023 said:I've noticed in every Z4 I've looked at the molding piece on the outside of the windshield, the larger black plastic piece that goes around the wiper base is usually cracked and completely crap. Is this typical?
Hello and welcome. Great introduction and from there it just gets better.stal023 said:I am looking at this generation, manual, convertible. What are common issues? Which year(s) are better? Specifics to look at when looking at used Z4s?
