we had our new conservatory built 3 years ago - never had a problem till now - there's a small leak from the joint at one end of the centre rafter where the ends converge - I've taken the internal end cover off and can see there's a small drip coming from directly above - difficult to see why because directly above is the external end cover - the roof is glass . Is it worth trying to put sealant up into the joint internally - there is a space where all the end panel glass sheets meet - difficult to fill with sealant - the other end of the centre rafter is exactly the same design with the same space but doesn't leak - the conservatory is 3 1/2 m in depth and 7 1/2 m wide with a box gutter where it's attached to the house - I suspect there's a leaky seal but to get to it will probably mean dismantling the roof ( a major job
Any suggestions ?
Any suggestions ?
