Is there an easy way to connect my phone to the speakers in my car? Or do I need to take the radio/CD out?
Car is a 2003 model with standard radio/CD player
Im going through this very exercise myself at the moment. 2003 E85 with BMW Business Radio.
My first option was to get the head unit out and fit a Bluetooth dongle to the back of it. This means getting the vents out above the radio first so you can access two bolts to release the radio itself, which entails using slim screwdrivers or similar through the vent fins to hold down two clips on the inside top of the vent. Could I release the vents? No I couldn't, after multiple tries. It got to the point I was concerned about breaking the plastic fins.
So, option 2 for me was to go hunting around in the boot under the floor covering immediately behind the centre console for the CD Changer wiring - and yep I found it in about 10 minutes, yay!
Even if you don't have a CD Changer fitted, early cars had the changer wiring in place anyway.
I've ordered a BlueMusic dongle with the wiring for the CD changer connectors, should be here this week. Fingers crossed....
There's quite a few resources on here and elsewhere online that can point you in the right direction.
I believe you need to have the Business Radio head unit as a minimum - there is a 'basic' head unit too, but I dont believe this is compatible. Other wise owls on here may know better.
Good luck!
Geoff
